I need to add wireless capability to my existing home network. I have a D-Link DI-704P router that seems to be working fine so technically I only need a WAP. However, the prices on the Linksys WAP and router are comparable (identical in many places).
First, let's assume I don't want to replace my existing router. Does it make any sense (and is it possible/reasonable) to configure the WRT54G as a WAP only? Basically, if I only want/need a WAP, is there any significant functional differences between these two devices that would lead me to one or the other? I admit that buying more than I need (i.e. the router) doesn't necessarily make sense but that's why I'm asking.
Second, is there soemthing compelling in the the WRT54G that should make me consider more seriously replacing my existing router? A couple of months ago I had a bad experience with a D-Link DI-624 wireless router (wired client disconnects, couldn't get VPN to work, etc.) which is why I am leaning towards a WAP at this point (and non DLink equipment). My router location is also not great so a WAP gives me more flexibility in placement.
TIA for any guidance.
Douglas Gallant
