this is a weird one -
Have a network with a WAP54G for the wireless... all is ok. Have a WET11 bridge down in the family room for xbox + tivo... all is ok.
Son wanted to move xbox to room and run an old WAP11 for access. OK - gaunlet begins...
First - what is the difference on the WAP11 between AP Client - ? Bridge (pt to pt) - ?
Well have it connected... sort of :) BTW - it is REALLY HARD to tell if wifi things are working since NONE of these access points have any display showing those stations currently "associated" with the access point. So, it's impossible to tell what's going on.
Anyway - back to current problem. I have the WAP54G, an old desktop, print server, router, etc all going into a "10mb hub" so I can see the packets on my protocol analyzer.
I connect my laptop via a crossover cable to the WAP11... ok Since I can't really tell the "associations" - it's like shooting in the dark. Anyway, it appears to be connected, as I can ping across the link... sort of -
Here's the weird part.... laptop (192.168.1.100) -> WAP11 (192.168.1.200) ----> WAP54G (1.245) -> "hub"
