I have recently splashed out on the said router and USB wireless adaptor of the same brand. Network is stable and running fine and I happy to report, which is something I guess! However, I have been scratching my head over the past week or so trying to get port forwarding work, to no avail. I have rung linksys and followed every step they suggest, and still the same result. I am assured by them that the router has the required port open and that everything is fine according to their port scanning s/w...
What I am trying to do is to create a secure tunnel from my work PC to my home PC (through company proxy) on port 443 using putty and copssh as the listener on my home box... Then use TightVNC to remote connect using this tunnel. Bascially, port forwarding a local port to 5900 remotely.
copssh is installed as a service and appears to be configured correctly, although I am unsure about how I would test this... As I said, the network is up fine and I have also been able to connect using logmein, which is ok, but pitifully slow! My n/w adapter is configured with a static IP and I have setup said IP in port range forwarding AND port range triggering on the router with no effect...
Does anyone have any pearls of wisdom (apart from buy a new router as it is not an option unfortunately!). I am pretty new to this networking lark and so I apologise in advance if I have left any vital info out... Thanks for any help!
Cheers
Tim
