I have a linksys WRT54GS using DD-WRT firmware with a high gain directional antenna to another access point some distance away (800-1000 feet).
When I plug ethernet into the WRT54GS, I can communicate without issue.
When I attempt to use a wireless connection into the WRT54GS, it 'sorta works sometimes', it's as if the box is deciding that there's a better signal here, and it broadcasts/receives over the stock omni antenna, instead of other the high gain antenna to talk to the other access point.
Any suggestions? I'm thinking I may just have to buy an additional access point, and ethernet connect it to the roof mounted (high gain antenna), and force the roof mounted one to only use the high gain antenna, and to ignore the stock omni.
