Setup:
Linksys WRT54G wireless router Firmware v1.00.6
(Wired) eMachines desktop running XP Home
(Wireless) Sony Viao desktop running XP Pro Linksys WUSB54G wireless adapter Driver version: 2.0.2.0 Linksys Wireless Network Monitor v4.2
(Wireless) Toshiba Satellite laptop running XP Home Dell WLAN 1350 wireless PC Card Driver version: 3.40.73.0 Dell Wireless WLAN Card Utility
I have a wireless network set up with the above computers on a cable connection through Cox Communications. DHCP from the router is disabled and all three computers have static IPs. The SSID broadcast is also disabled. WEP security is enabled.
The wired desktop and wireless laptop have no connection issues at all. Despite the SSID being hidden, the laptop has had no problems continually accessing the network over the past 3 weeks. This morning I switched the Sony from wired to wireless and have had nothing but problems with it. I verified all the settings with the laptop (IP, DNS, etc.), but could not access the network with the Sony. After alternating between the Linksys network monitor and Windows Wireless Zero Configuration, I finally enabled the SSID broadcast. This allowed me to connect to the network and the Internet (via Firefox/IE), but I receive the message "You are connected to the acess point, but the Internet cannot be found." in the Linksys monitor. The big issues is that I cannot access the Internet/streams from Winamp, Windows Media Player, iTunes, etc. Also, if I disable the SSID broadcast - even after saving all the settings using the Linksys monitor - I immediately lose the connection and cannot reconnect until I enable the SSID broadcast. Firewalls are not the problem.
Any suggestions would be appreciated. Have been fighting this all day and don't know exactly how to proceed (other than wiring the Sony to the router again).
