Hi all
I have a problem with my Linksys BEFW11S4 and my 3 wireless clients.
when i use it without WEP encrytion all my clients work and do get an ip adress from the router.
When i activate WEP encryption , it will not provide an valid ip address for the wireless only the cards internal 169.xxx.xxx.xxx I have resat the router and started from scratch, i have tried to enable/disable SSID, changing WEP codes and all with no luck The router is running with firmware 1.45.10 it's a V2 router. All clients are running WIN XP Pro Sp2.
All suggestions are welcome before i go crazy and go out and buy an 3Com router
Brdgs Peter Larsen
