P II Homebuilt, Asus P2B mobo, 500mb RAM Windows XP SP1 Linksys WRT54GX, WMP54GS, WMP54GX
Wi-Fi network has been up and running without problems for more than a year. One Dell laptop and one HP laptop have communicated with the router in that time without protest. The HP laptop crashed and while it is being repaired I needed to press a retired PII into limited service including an Internet connection. Previously it had been successfully connected directly to the modem via a USB cable and installed drivers. That connection was removed per our request to the cable company when the machine was retired. Since I am building a new desktop machine that will need a wi-fi card, I purchased a WMP54GS v1.1 on e-Bay thinking it could serve the old PII now and the new box later. I installed the drivers, then the card as instructed. DEVICE MANAGER SEES THE CARD AND REPORTS NO CONFLICTS. The Linksys config software caused repeated crashes, I switched to the Windows setup. The Linksys Netclient app can not find the signal. I opened the Wireless Network Connection Properties > Wireless Networks > Preferred networks
and click OK. The Preferred networks windows shows the SSID with a red X. I click the Available networks > Refresh button and the red X goes away however the SSID does not appear in Available networks. Close the window and the red X remains over the Network Connections LAN entry. I have disabled all firewall and other filtering/monitoring software with no change. I updated the driver and switched antennae also with no change. I spent two hour by phone with LinkSys Tech Support with no success. They did not walk me through any test or configs and just said the antenna or the card was defective and that they would not replace it because it was obtained through a third-party vendor.
I ordered the WMP54GX from newegg expecting to finally get a connection and it does not even show up in Device Manager. There is not even a Network adapters header so there is no where to go with that one.
At this point I don't know if either or both of these cards is defective. I have no other box in which to install them to see. I am less experienced with this aspect of computers than others and may well have overlooked some part of the process that is obvious to more experienced users.
Suggestions are welcome and gratefully appreciated. Thank you.
