Linkstation 160GB on WiFi does not connect to network
Subject: Linkstation 160GB on WiFi
I have linkstation 160 GB ( on a wireless network). I can acces it perfectly from a PC, hardwired to my dlink 614+ wireless router. IP address is set by DHCP server.
My HP 9015 laptop (XP home 2 ) can only connect to linksation via Broadcom wireless link. The link is disconnected the moment I open the setup utility from my browser. I am also not able to access linkstation from the Run command (like :\\\\hd-hlan420?
My Client Utility does not open the linkstation from my laptop, which it always does from my PC.
Linkstation setup and ping to Linkstation/s IP adress work normally from may laptop.
Firewalls are set not to block the linkstation.
I would appreciate any help.
regards,Jurij
Jurij Kus
Trzaska c. 51,SI-1111 Ljubljana Slovenia
++386 41 692684
Tardus_merula
