yesterday I formatted my laptop, and since reinstalling windows I started to have wireless connection problem:
it finds excellent signal and connects to the router fine, but after trying to get an IP from the router it says: limited or no connection. Checking details I see that it couldn't get data from DHCP (no IP, no gateway, no DNS. windows automatically takes a self assigned one)
setting manually ip, gateway and dns doesn't help.
on the other hand 'Lan' connection, using normal eth Cable works perfectly.
the problem started after reinstalling windows, so this means with normal xp with service pack 1 and also with service pack 2.
does anyone have any idea on how to solve?
thanx Giulio
