I've found this question is frequently asked around the internet BUT... here's a new twist. I've tried everything I know of. Changed the WEP key. Tried to restore Windows. Even that didn't work! NOTHING is fixing this problem. I have a Gigafast Wireless Router, if that makes a difference.
I even tried using a USB wireless adapter from my desktop computer to connect wirelessly with my laptop (this isn't a problem on the desktop
- go figure) and even that did not work. I tried a WinSock fix, and that didn't work. Tried releasing/renewing, but still nothing. I'm able to connect to my network and other neighbour's networks, but I can't actually use the internet wirelessly.
I'm out of ideas, which is why I came here. Is there ANYthing else I can do, or am I just SOL? :confused:
