The building I live in has wireless G connection but there are no wired ethernet port. Now if I want to use Linksys PAP2 adaptar for VOIP, a broadband ethernet cable has to be connected to the adaptar. So my question is, Is there any way to convert the wireless signal to wired signal which can be fed into a router and enable me to use the VOIP adaptar?
I have a Linksys USB wireless network adaptar and a router that I can use for this project if it is doable.
thanks
ims
