For some reason one of my cetrino laptops refuses to connect to my network, it's been working perfectly before.
It will keep comming up saying "one or more wireless networks is available, to view a list click here etc etc..." and when I do, my network is visible and I click connect and just does nothing, the same message will pop up again within 2 minutes.
I've gone through all the config, changed the SSIDM the channel, the WEP password, everything!! I've reset the router and started again. But the laptop just won't have it. It will connect, but after a reboot or standy it won't connect again.
I have other PCs happily connected to the same network all day long, distance isn't the issue and I have configured lan IP reservsation but it just doesn't stick...
please help?
