Greets.
Can anyone help me get my mum's laptop to remember it's wireless settings? (if that is what the problem is) I can connect to the router wirelessly but when the laptop is turned off and back on again it has to be configured all over again. It has XP - from the system tray I start up 'Wireless Network Settings' -> 'view wireless connections' -> 'Wireless' tab and check 'use windows to configure wireless settings' (I've probably not remembered the exact wording here, I'm on a different machine right now) - when these steps are carried out it can connect. It would be much better if this would happen automatically. Anyway, I hope that is sufficient info for someone to realise what needs to happen. The router is fine and there have been 3 network adaptors tried out so I figured it was the laptop. The shop it was got from have advised us to reload xp - yikes!
thx in advance, Hughie
