Hi
- posted
16 years ago
Hi
Did you check security and set the key? Is your router set to B & G connections? Are you getting an IP address? Have you checked your Firewall settings to allow connections to router? Do you have another computer that is wire connected to the router and does it have connection to internet? Is the wlan on, on the laptop? Is the laptop seeing a wireless network?
Ok first you do not need to run a new connection wizard as your windows wifi connection should show the available wifi networks for you to select one to connect to.
now find out if you are actually connected:
Start > Run > type "cmd" to prompt to DOS and type "ipconfig" and hit Enter; you should see your IP address leased from your router. Normally on linksys the IP address is 192.168.1.xxx.
then from your DOS prompt type: Ping yahoo.com
just to make sure that you are connected to the Internet.
-aljuhani
-aljuhani
Ive done as you have suggested above and this is what i get in the cmd.exe window...
C:\\ Document and Settings\\Sony}ipconfig
Windows IP Configuration
Ethernet adapter wireless network connection: Media state............ : Media disconnected
Ethernet adapter local area connection: Media state.............: Media disconnected
Ok then you are not connected, please do the following:
Start > Connect To > Show all connections
Now you should see a connection named " wireless network connection "
double click it and it will display the wifis available to connect to. select your wireless hotspot and connect.
now you should see an icon on task bar showing the connection status.
-aljuhani
-aljuhani
Hi Nothing on start Menu to 'connect to'.. went to network connections via control panel wireless network connection icon says not connected,firewalled When i click the item a 'Choose a wireless connection box comes up but says ' Windows cannot configue this connection'
Ok then a third party software is managing your wireless card and you can use that software to connect to wireless lan or change over to Windows wireless zero configuration.
-aljuhani
-aljuhani
Hi The Windows wireless zero configuration has worked!!.. I turned windows firewall off to do it.. If i turn it back on will i lose connection.. if so what exception would i make to allow connection.. or wouldnt it affect it? Thanks
Personally I do not use windows firewall and instead relying on Zone Alarm / Norton Internet Security and Linksys built-in firewall. Windows firewall require configurations of services that you will require to access the Inernet and in addition I would guess defining your trusted zone.
-aljuhani
check this link:
-aljuhani
-aljuhani
Hi
The windows zero configuration work for half hour which enabled me to get all windows updates etc but now i have trouble getting it to stay 'ON'.. Ive set the setting to Automatic and clicked start.. it connects ok then within a minute or so it stops.. I watch it in the configuration window go from start to stop.. Any ideas? Thanks Dar
first you'll need to define your wireless connection as the prefered connection and select only to connect to prefered network.
double click the wireless connection on task bar then under General tab select properties then Wireless Networks tab and there enter your SSID under prefered network.
Click advanced and pick the first option (prefered networks) and make sure the bottom most option to connect to non-prefered network is disabled.
Or otherwise it could be a wifi issue that require changing of your broadcat channel.
-aljuhani
