My computer uses XP O/S and a dial-up connection. Having disconnected the telephone line to the computer, but without uninstalling the dial- up software (in case I had to use the connection again). I set up a LAN connection using the Home Power-Plug system, between a broadband wireless modem router and my computer. Network properties shows that the Lan connection is working and running at 100mbps. (no red crosses showing in task bar) Using Internet Explorer, however, I am not able to connect to the internet. Each time I attempt to connect to the internet, the dialup connection flashes on the screen. Is it neccessary to make the Lan connection the default - how do I do that.? Do I also need to uninstall the Dial-up software.?
Thanks in anticipation.
