When using XP's built-in wireless software, every 60 seconds, there is a lag spike on all devices, I can see by each machine pinging each other and/or the router and/or external Internet IP:
Example: Reply from 192.168.1.1: bytes=32 time=1ms TTL=64 Reply from 192.168.1.1: bytes=32 time=1ms TTL=64 Reply from 192.168.1.1: bytes=32 time=425ms TTL=64 Reply from 192.168.1.1: bytes=32 time=1ms TTL=64 Reply from 192.168.1.1: bytes=32 time=1ms TTL=64 [...57 seconds...] Reply from 192.168.1.1: bytes=32 time=1ms TTL=64 Reply from 192.168.1.1: bytes=32 time=777ms TTL=64 Reply from 192.168.1.1: bytes=32 time=1ms TTL=64 Reply from 192.168.1.1: bytes=32 time=1ms TTL=64
Yet when I use the manufacturers own Wireless configuration software that came with the drivers, the lag doesn't occur, WHY? (I hate using manufacturers software - ugly and bloated)
