I have a Linksys WRT54GS with speedbooster in the living room, connected to my cable modem. In a kids room, I have a WUSB54GS with speedbooster that I am trying to connect to the router. The kids PC will connect, signal strength is good, but it will drop the connection shortly. I can go to the properties on kids pc & it will say "Connected to access point, but can't find the internet". But even that doesn't seem to be the case, because I can type in 192.168.1.1 in my browser & can't connect to the router. I have tried removing & re-installing software, tried it using the Linksys program, as well as the Windows built in wireless settings, tried with static or DHCP address. I have even tried switching out the WUSB54GS! I am using 64bit WEP & have broadcasting turned off. Even stranger is that there is a laptop with built in wireless settings that connects just fine from the same room! What am I missing?!?!?!
- posted
17 years ago
