(message posted anon, due to usenet censors/failure to propagate)
Does anyone which drivers to use the EUB-362(EXT) for win98SE?
There are at least three different packages on the net for it.
One for "win98/ME" at the engenius site and a broken link for win2000/xp (way to go Engenius)
One on the cd that comes with the manual which says minimum requirements w2000/xp for the device-file date is several months earlier than others-funny the ADVERTISE support for win98se, then after they have your money they send you a cd manual that says minimum requirements w2000.
two from a dealer, one for win9x/ME that is identical to one at Engenius and one for w2000/xp that has a later date than one on cd.
Nice the way they make everything so clear. No suprise BIG on marketing, lousy on support.
