Junk powerline extenders
I had one of my folks pick up a Netgear HDX-101 powerline adapter kit with the idea that we'd network our new T&A clock to the office computers without having to trench.
The total wire distance from the clock to the breaker, then from the breaker to the office is 70'. Both outlets on the same leg of single- phase 110. No carrier detected.
So I brought them both into the office. If the two are connected on the same branch, and are less than 20' apart, we get carrier. If they're on different branches of the same leg, no carrier.
So I plugged them both into the same outlet, and did some tests.
1) they're rated at 200mb/s but have only 10/100 ports... HUH? 2) they averaged under 8mb/s throughput when on the same outlet. Ok... maybe they're swamping... Move them to two outlets eight feet apart on the same branch.... 7mb/s.
I'd say this is not the way to stream video... no?
LLoyd
Lloyd E. Sponenburgh
wow - I'm surprised they didn't work better for you
if the 85rmbps units would work better...
years ago we used some Netgear telephone wiring bridges from the office to the loading dock, and they worked great..... but don't see anything like that listed anymore
ps56k
SO - decided to try the powerline adapters to the time clock vs your original WiFi AP idea - (from your other posted thread)
BTW - OT - is there any other way to "reference" another newgroup thread ?
ps56k
Did you get ONE or two (or more)? (above you didn't make it plural ie kit'S) They work in pairs with each other at HS, or much slower with other units.....
Peter Pan
I heard that those 101 s are not so good. The 103s are.
Steve
seaweedsl
"Peter Pan" fired this volley in news: snipped-for-privacy@mid.individual.net:
"kit" implies "the things you need to build xxx....". There are two adaptors in a kit. Otherwise, I'd have said, "I bought ONE ethernet powerline adaptor, and it won't hook up to my computer... (duh!)."
LLoyd
You are ASSUMING.... look at the website... a kit only has ONE (not two as you ASSUME, they used to in the past but not anymore)......... So duh! yourself from
look at the dot points on that page..... # Plug one HDX101 into your router and nearby electrical socket, then plug a second HDX101 into an electrical socket near to the device you wish to network¹ ¹ Requires use of at least one other NETGEAR HDX101 (sold separately).
So again, a kit doesn't imply two, as a matter of fact it specifically (in writing) says you need another one sold seperately (see above) so did you get one or two(or more)
Peter Pan
Twit!
THIS is what Netgear CALLS a "kit" --
Powerline HD Network Kit HDXB101 Powerline HD Network Kit from NETGEAR
THIS is what Netgear CALLS an "adapter" --
Powerline HD Ethernet Adapter HDX101 Powerline HD Ethernet Adapter from NETGEAR
And as skilled as you are and picking and eating nits, you missed entirely that the KIT is the very next listing after the ADAPTER you copied and pasted.
Displayed like this on NETGEAR's page ---
Twit!
LLoyd
Going to Amazon to check buyer's comments on this product you can see why I've been recommending that people go with the netgear 102 or 103 (104 is same) and NOT with 101s. There are good reviews, but the bad ones are telling in this case:
Quote:
I attempted to upgrade my electric wiring based network from Netgear XE104's (rated at 85Mbps) to the Netgear HDX101's (rated at 200Mbps). The performance of the HDX101 network was substantially slower and less reliable than the XE104 network with exactly the same devices attached to the XE104's and the HDX101's. I did not have both networks operating at the same time even though a HDX101 network supposedly can co-exist with a XE104 network. I highly recommend the Netgear XE104, but was very disappointed in the HDX101. I would not even recommend the HDX101 for use on the same electrical circuit in the same room. The HDX101 also becomes very warm in operation. ___________________________
Quote: Beware: HDX[B]101 doesn't follow the HomePlug-AV standard..... It follows a demonstrably inferior, European-brewed standard. Netgear simply jumped the gun and didn't wait for HomePlug-AV chipsets to become available. This HDX[B]101 product is a dead end, because HomePlug-AV will win the standards war.
If you truly need higher speed than is attainable from HomePlug-Turbo products such as Netgear's XE104 (85Mbits/s best-case raw channel bitrate), then wait a little while for HomePlug-AV-compliant ("200Mb/ s") products to hit the market in the USA.... _____________________________
Comment: that's an old post - HomePlug-AV is now availible, I believe.
Here's an comment that may actually help with what you now have:
Quote: One thing that we noticed though was the transfer speeds still weren't that great. After some playing, a friend we stick a switch between the router (linksys) and the powerline ethernet adapter, and that did it - transfer speeds went through the roof (at the advertised speeds)............ I recommend buying a cheap switch (got mine for $10) and inserting that between the router and the "main" powerline adapter and you'll be pleased.
________________________________________________
Steve
seaweedsl
ps56k
