Hi there,
I'm looking for some technical specs about the 3Com=AE Wireless 11a/b/g PCI Adapter (3CRDAG675). Neither 3com's knowledge base nor the technical specs / data sheet coming with the PCI adapter details the following:
Which PCI slot standard does this PCI adapter require? Will it work with PCI 2.1 or does it require PCI 2.2?
Can anyone help? Thx,
Markus
