The thread on corporate snooping via VPN, and in particular the comments about VPN terminating access to the local network have me wondering whether there is a way to keep access to the local network when VPN is running? I have a pc that I use to VPN to my work and when it is at home also use to access some non-work sites (e.g Fidelity Investments and ESPN). Now, some of the non-work sites require access to ports that are normally blocked from the corporate internet. However, if the machine could talk "directly" (i.e. via the local lan gateway) to the site, the machine could still access them as I don't have those ports blocked on my router. (I can still access some of the site features with VPN, but the streaming quotes don't come through, for example.)
Is it possible to do that, or does VPN truly remove one from the local net (by forwarding all packets via the tunnel)? I vaguely recall that the wireless software setup had some entries for "local" machines, so that one could use ones home printer. However, that might just be the wireless connection and not VPN. I vaguely once remember RDPing (using Windows remote desktop) from the laptop to both my home desktop and my work desktop, but perhaps I did home with VPN off and work with VPN on. However, if it is possible to punch holes in the forwarding, then all I have to do is determine what addresses and ports I want to access via the local gateway (after verfying that it is also permiss- ible, since not everything one wants to do, one is allowed to do).
