Ok, I have 2 identical wireless routers. They're Linksys Wireless G 2.4 GHZ routers. I have router 1 hooked up to my cable modem acting as the router for my network both wired and wirelessly. Router 2 is not hooked up at all. What I'm wanting to do is hook up router 2 in another room and have it connect to router 1 wirelessly. I would like to be able to hook up wired devices to router 2 and have the data travel from router 2 to router 1 to get out to the internet. I'm trying to avoid running a stretch of Cat 5 between the two routers basically. Is this possible? If so, any walkthroughs on the setup anywhere?
Thanks.
