Installed Linksys WRT54Gs on Windows XT and unit setup fine. PC and internet work fine.
My Pocket PC 2755 sees the wireless WRT54GS router. But...
The connection is made at -26 dB and a second later it is dropped (disconnected). Then it reconnects for a couple of seconds and then disconnects. This continues forever.
Any ideas? Any setup changes I should try?
Also, don't seem to see any icon to launch a way to configure parameters. Is there one?
