It all started with hardware failure on wife's desktop. Swapped her HD and NETGEAR WG311v2 PC Adapter into another computer. Did the Win XP Pro setup/repair thing, loaded the NETGEAR drivers and software. After much fiddling, established a wireless connection, but every time I enable WEP the IP address will not renew and cannot connet to internet or email. Disable WEP and reboot and all is well.
Her PC is WIN XP PRO (SP1) with 311v2 as stated. My PC is also WIN XP PRO (SP1) hooked by ether to a Westell Versalink 327W router.
I have tried all of the following several times - removed the adapter drivers in normal and safe mode and reinstalled (with updated drivers), removed and reinstalled the card, run ipconfig to release IPs, tried to connect with NETGEAR software and with windows controlled, reset the router, several different WEP keys.
At the moment, she is connected with SSID disabled and MAC enabled, but I don't thing that is the way to go long term. Oh, I did manually enter the IP/subnet/etc, after deselecting automatic select IP ,but that did not work either.
Any suggestions would be gratefully appreciated. I'm completely out of ideas. Thank you in advance. HH
