Hello,
Hope some of you folks can help me out and thanks in advance!
I just got this Acer laptop with a Broadcom 802.11g wireless card built in! I also had a Toshiba ,which my husband is using now, which has an Intel pro
2200BG built in! We are running a wireless home network using a D-link DI-624I assumed before buying that the Acer should perform better, or at lease the same, knowing that it had a dedicated G card unlike the Toshiba which has a B/G card! Do I have a faulty card or is this just a matter of settings? It is new so I can always take it back or replace it! Thank you for your time and hope to hear from you!
Lisa.
