also have a Dell laptop with Intel PRO/Wireless 2200BG Network Connection.
phone near it. This is really a problem the way PuTTY doesn't recover.
Strong sucker. Is that Panasonic one of those 2.4Ghz "super-duper, enhanced-range" cordless deals?
Yeah, I also had interference with my old 2.4Ghz phone as well. The phone didn't break my network links, but would slow data down somewhat. Most annoying was that the interference from the AP's could be heard in the phone though. I was always hitting the damn channel button on the phone to find some clean air.
Gave that phone away and since been using a 900Mhz phone. Works fine. I have 802.11g and 802.11a in the air, so a 5.8Ghz phone would've caused problems with the 802.11a.
You could go with either. 900Mhz will give you more range, if thats something you need. Obviously, get a digital SSMA 900Mhz phone and not one of the old analogs.
I bought a Uniden 5.8 GHz DXAI588-2 at Target. This phone says 5.8, but also uses 900MHz. It's junk. Comes with two handsets, but only a 10 number memory, and the audio quality was dreadful.
I took it back, and bought a Panasonic KX-TG5453 at Costco. This is a three handset, 5.8GHz-only. I've always liked Panasonic phones and answering machines, and I thought there was a set on sale at Target, but I didn't see it at the store.
This set cost twice as much as the Uniden, but it has three handsets, is fully featured, and the audio quality is superb. Each handset has a speakerphone, spoken caller ID, separate phonebooks, and distinctive ringtones, and different lights on the antenna for distinctive ringing.
It even says "Wireless Network Friendly" on the package, ignoring 802.11a, I suppose. It lists 802.11b/g friends on the specs.
