I'm using a WRT54GS router and a WPC54GS pcmcia card to connect my network. So I want to increase the distance of my link up to 650 feets ... Witch antenna should I use to do it, and how can I connect a external antenna in my devices ???
Regards !
Regards !
I would recommend you two things:
1) To change your firmware so you can increase your power, try visiting2) Visit
I have a very slightly used antenna system that might work. If interested, send me e-mail
snipped-for-privacy@hotmail.com
