I've been trying to install my USB D-Link WUA-1340 wireless adapter on debian. I installed the dr71wuy.inf drivers using Ndiswrapper. I got a driver present and hardware present message. However, when booting up or plugin in the card I get the following message:
usb 1-2.1: new full speed USB device using address 3 ndiswrapper: driver dr71wu (D-Link,11/03/2005, 1.00.01.0000) loaded Unable to handle kernel NULL pointer dereference at virtual address
00000000 printing eip: d0b03083 *pde = 00000000 Oops: 0002 [#1] PREEMPT Modules linked in: nls_cp437 isofs ipv6 floppy parport_pc parport evdev pcspkr pci_hotplug hw_random intel_agp uhci_hcd 3c59x agpgart capability commoncap ndiswrapper usbcore psmouse ide_cd cdrom genrtc ext3 jbd ide_generic piix ide_disk ide_core sd_mod ata_piix libata scsi_mod unix font vesafb cfbcopyarea cfbimgblt cfbfillrect CPU: 0 EIP: 0060:[] Not tainted EFLAGS: 00010246 (2.6.8-3-386) EIP is at 0xd0b03083 eax: 00000000 ebx: c9764000 ecx: 00000000 edx: 00000000 esi: ffffffed edi: ceedac00 ebp: ce88fdb4 esp: ce88fdac ds: 007b es: 007b ss: 0068 Process khubd (pid: 526, threadinfo=ce88e000 task=ce834c90) Stack: 00000000 00000000 ce88fe34 d0b016cb 00000000 0000000c c9081460 00000001 d08d6cdf 00000000 00000000 00000000 d0b2e295 00000000 00000000 00000020 d0b48748 ffffffed 00000000 d08d9d9c d0b48748 c9764220 c9764000 d0b03774 Call Trace: [] wrap_kmalloc+0x42/0x7d [ndiswrapper] [] NdisMInitializeTimer+0xf/0x2c [ndiswrapper] [] ether_setup+0x0/0x86 [] miniport_init+0x57/0x61 [ndiswrapper] [] ndiswrapper_add_one_usb_dev+0x93/0x15a [ndiswrapper] [] usb_probe_interface+0x36/0x40 [usbcore] [] bus_match+0x2e/0x4d [] device_attach+0x41/0x7d [] bus_add_device+0x3f/0x6e [] device_add+0x72/0xda [] usb_set_configuration+0x2dd/0x334 [usbcore] [] usb_new_device+0xb7/0x116 [usbcore] [] hub_port_connect_change+0x283/0x313 [usbcore] [] hub_events+0x224/0x2da [usbcore] [] hub_thread+0x0/0xe4 [usbcore] [] hub_thread+0x1d/0xe4 [usbcore] [] autoremove_wake_function+0x0/0x3a [] ret_from_fork+0x6/0x14 [] hub_thread+0x0/0xe4 [usbcore] [] autoremove_wake_function+0x0/0x3a [] kernel_thread_helper+0x5/0xb Code: c6 00 00 eb e4 8b e5 5d c2 08 00 cc cc 55 8b ec 83 ec 0c 8bThe adapter does not work (lights do not blink). Any ideas?
