I have a modem-router wireless and when at window xp boot I need to connect with internet via wireless the connection is very instable. In a few of seconds the connection go down and immediatly go up about three times and at the third time the connection is definetively out. I've changed a lot of time the configuration of the modem and of the notebook but with the same results. The only way to connect my modem to internet is to restore the parameters of the connection using the menu in the task bar wireless icon. After this I can connect and disconnect the modem all the times I need becouse this problem, for the same day, is solved (!!!???!!!). Have you any idea about how to solve this question forever?
- posted
17 years ago
