I need to connect a small LAN to a larger LAN that's about 600 feet away. I have clear line of sight. I'm unable to run a cable between the two locations.
I have a pair of D-Link 2100APs but was never able to get them to work as a reliable P2P bridge.
I would love to use the antenna cables and panel antennas from the D-Links if possible, and save the few $hundred expense of new cables and antennas. But the 2100APs simply _would not work_ as a bridge. Lousy firmware was the explanation I got back then.
Any suggestions?
Or - can someone confirm that whatever firmware revision D-Link's up to on the 2100APs will actually _work_ consistently if they're set to be a P2P bridge?
Thanks.
