I am not at all familiar with thinkpads, but any mini-pci wireless card should fit into and work in any mini-pci slot on any system.
Let me correct my previous post. I think I read somewhere that IBM thinkpads have some BIOS or something which prevent use of devices other than those approved by IBM. That may be the case?
Hi, I have an IBM thinkpad R40 Celeron (model# 2681 CTO) that I want to add to my home wireless network. It's wireless upgradable ready (the antenna wires are already installed and there is a mini pci slot) I've been looking at the IBM 31P9107 as it supports 802.11a/b/g. In trying to determine weather this card is compatable with my system I found the following information on the IBM USA site:
On this page,
but on this page,
Anyone know which is true? Thanks, Tracy
Dunno. Thinkpad and wireless are potentially a mess, where a substantial number of mini-PCI cards simply do not work with the IBM drivers. (They may work with the Intel, Broadcom, or vendor drivers). See:
I can't find the 31P9107 in any of my IBM references. However, the
31P9701 is a valid number. This URL sorta hints that it will work with the R40.Do your really need the 802.11a capeability? If not, the selection of
802.11b/g cards is much better.
Thanks Jerry, I'll look into the BIOS and see if I can get some clues... An IBM card is (obviously) going to be more expensive because of the name but I want to make sure that I get something that works...
It was the 31P9701 I was origionally looking at (I just fat fingered the 7 in there somehow...) I have been looking at the 2200bg cards since I origionaly posted and your right, I doubt that I will need .11a. Added with the fact that b/g caeds are about half the price I'll probably go that route. I just hate to spend a dollar before I know that it's going to work
