I need dual bank recommendation - Page 3
Threaded View
Re: I need dual band recommendation
not that well even when it was new. hopefully they're *really* cheap.
no single router (or any product) is going to be ideal for all
customers or situations.
That is why I am looking for a replacement.  They
are cheap.  My customers balk at price of the really
good stuff, such as Watchguard's Firewalls, which include
routers
I agree with you except for the reliable part.  Some of
the stuff is very reliable.  Some is a nightmare.
Also, there is no phone number to call.  You can only
chat with them. It is a total pain in the ass if it is
the router that is the issue.  You have to direct connect,
wait an hour on hold, get some instructions, hang up
with them, rewire the router, try to install the update
they say will fix it, the update fails (always), back to
direct connect and an hour on hold ....  you get the
picture.  It sucks.
y to set up
So far I have recommended customers pitch their Edge Routers
into the trash.  I replaced them with something else.
Problem solved.
pitch them this way. edgerouters are great. they're inexpensive and
*very* capable.
however, they're not consumer products and not easy to set up for those
who aren't network gurus. the true power is via the cli.
Okay, one crapped out two hours into operations.  It took the
customer over three weeks to respond and over three months
to get a replacement from Ubiquiti.
The replacement was sent with the first firmware
and refused to update.  It also had a dead PoE port,
even though it was configured to be on.
Ubiquiti's service SUCKS.  The customer has been fighting
with them for over a month now trying to get a refund.
No s***!
I am and they are still obnoxious to set up.
I support Linux and love the cli but still find edge
routers obnoxious.
Oh they supposedly have a nice "Wizard" to set them up.
But they do not ship them with the firmware that has the
wizard.  And they won't update. And there are no direction
on line to do it manually.  They way to use the "Wizard".
It should only take me five minutes to set up a router.
Lan network: network, mask, IP address, DHCP server,
DNS.  Wireless: security, SSID, key.  Reboot.
Ubiquiti ain't it.
Best place to store an edge router is in a trash can.
the wizards are included in the stock firmware, plus there's plenty of
how-tos online, from ubiquiti and others.
that takes less than 5 minutes, and most routers don't need a reboot to
take effect.
Not when they ship you out of date firmware that the
wizard does not exist in and the firmware won't update.
The wizards are nice, if you can get access to them
and can figure out their weird/cumbersome way of doing things
that must be *really* old firmware. the wizards have been there for
years.
why won't it update?
worst case, download the firmware via another computer and update it
directly (also not specific to ubiquiti).
for edge products, it's in the wizards tab in the top right corner, and
much easier than dealing with their web ui.
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA256
anything older than the ER-X ships with 1.2 (IIRC).  Wizards are a 1.5
or 1.6 addon, though they're kinda bad til 1.8 or 1.9.
-----BEGIN PGP SIGNATURE-----
iQEzBAEBCAAdFiEEBcqaUD8uEzVNxUrujhHd8xJ5ooEFAlz+yoEACgkQjhHd8xJ5
ooGkfwf/SvffbfDXPyTBUHTZYhsQafxZA5/SE6csVUCrujx4DFv7vT7XweUzUoAj
N0jaUAvbb/2AUFp5//BtrKCH7skNjUnoJ0bSQ6+UEHJiw4EZEDGxSpAqS4jHAj9k
ARw5w9BintmF/HKvJBKEz9BsWnaeS1zpa+8rf+tFDaPh7cm5hiOjYueFCy7l5LW0
j4a5JwrrfQt0fmuGfSSX5uojLNfLqochK/4Iq3uGgj9czx6dLdMEjUABwJTTa8b8
d3JHFUV2v5RN+U3zok171eboc80P/tzRf4m37xUEJBSadA6nqSmq/0SMAQNDN60q
2JJ8A1g6AaJ0E1M/KWRgwooOofaGyQ==
=M24i
-----END PGP SIGNATURE-----
|_|O|_|
|_|_|O| Github: https://github.com/dpurgert
|O|O|O| PGP: 05CA 9A50 3F2E 1335 4DC5  4AEE 8E11 DDF3 1279 A281
Beat me!
That is what I did
Blah. Edgerouters suck.. Ubiquiti trying, and failing, to produce
something approaching the functionality of Cloud Core Router
nonsense.
Hardly. I've been using Ubiquiti gear since Day 1.  I've probably
deployed $100,000 worth of their hardware, but they haven't come up with
a router or switch that's worth a crap.  Not when you compare them to
the competition.  Sure, their stuff is better today than it was 5 years
ago, They're improving, but no.. You take hardware like Netonix's WISP
switch and there is hardly a comparison.  Short of a firmware update,
those boxes will run for years, literally, without human intervention. I
can't remember the last time I saw a piece of Ubiquiti hardware that had
an uptime of greater than 100 days or so. They'll stay up longer if they
serve very light loads, but you start pumping a few TB a day through
them and they go down faster than a broke hooker.
Ubiquiti has spread itself too thin and lost sight of its core business.
They want to be everything to everybody and are no longer specializing.
They want to supply carrier class gear, they want to supply SOHO gear,
and they want to supply everything in between.  Cisco made that mistake
too.. And they went bankrupt..
Specialization breeds competence.  There's a reason why Brain Surgeons
are specialists.. There's a reason why a plumber usually doesn't
moonlight as a framer..
Ubiquiti revolutionized the wireless hardware side of the equation by
making it truly affordable and easy. They need to stick to that and
leave the routing and switching functions to specialists. I bitched the
day they started implementing firewall and routing functions into their
shit.  Their firmware hasn't been equally as stable since.  I remember
when you could get 2 years out of a Powerstation 5D before you had to
reboot it..
Well, enough ranting I guess  :)
h
 to
years
te,
I
d
y
stake
eons
 remember
That does explain what I see with Ubiquite.  Some excellent
stuff and some junk.  And UI's from hell.
On 6/13/19 3:22 AM, T wrote:
<snip>
It's always one step forward and two steps back for them.  The new AC UI
8.x is horrific.
On the M class gear (firmware 6.x) you get a separate page for a lot of
stuff. Site survey for example.  I'll run a survey, print it out, and
cross check it with available frequencies on a cheat sheet I made that
has all of them in 5 mhz steps.. Makes it super simple.. Low tech as it
were.. But I can do it while sitting on the couch..
With the new javascript-hell UI on 8.x you can't do that.. The site
survey is simply a javascript overlay and you cannot detach it to print
or even screenshot if the list requires scrolling.
The moment Cambium gets their UI just a tad more polished, develops a
decent network monitor, and stops doing ultra-retarded crap like
hard-coding usernames, I'll tell Ubiquiti exactly where they can cram it.
(yeah, they actually hard-code the username of ADMIN into the firmware..
You can't change it..  Their security guy needs to be fired and then
sued for gross incompetence)
On Thu, 13 Jun 2019 23:59:19 -0700, Johann Beretta
I have an ISP-supplied gateway router here that has both the admin
username and the password hardcoded. (Printed on a sticker on the side
of the unit, with no way to change either field.) With such a
lighthearted approach to security, I'm not sure why they didn't take the
extra step and make the whole thing accessible from the Internet by
default? :-/
they probably did, so they can check its status, push firmware updates,
access it for tech support issues, find out how many devices are being
used, etc.
customers who use a verizon provided router can log onto the verizon
web site and see not just their wifi ssid name, but the password too,
as a 'convenience' in case the customer forgets either or both.
i would be surprised if that router didn't also send the admin password.
verizon customers should use their own router, ideally replacing the
provided router, but if that's not possible, in line.
<https://www.speedguide.net/port.php?port=4567
  Verizon Actiontec Routers have a web server listening to this port.
  Verizon FiOS uses it for "secure server connection to automatically
  monitor/upgrade the router firmware when connected to the FiOS
  network using a MOTIVE server connection on port 4567". The firmware
  shipped with Verizon's CPE does not allow port 4567 to be blocked
  easily.
<https://forums.verizon.com/t5/Fios-Internet/Guy-accessed-remote-adminis
tration-port-4567-on-my-router-Thanks/td-p/241017>
  Guy accessed remote administration port 4567 on my router. Thanks,
  Verizon!
  From what I've been reading all he needed to get in was the router's
  ethernet MAC address and some administrator password that's
  supposedly available online. Is this correct?
Convenience usually wins over security.
In the dark ages of conglomerated modem, router, switch, and wireless,
AT&T started out by putting a label under the base of their units with
the login and password inscribed.  Extra credit for making the label
difficult to remove.  None of their customers could find it, but all
the hackers had no problem.  AT&T eventually moved the label to side
of the box, where customers would have no problem finding it.  As an
added security measure, they also included a 10 digit "modem access
code" for making configuration changes.  This was also printed on the
label.  Customer could now find the login and password, but rarely
succeeded in typing the modem access code in fewer than five attempts.
The latest AT&T U-Verse "univeral" box now has the modem access code
in ASCII, with upper case, lower case, numbers, punctuation marks, and
symbols thus making it both impossible to type, but also impossible to
read over the telephone.  (What's an octothorpe)?  The label now
contains only the wireless SSID, wireless password, and modem access
code in very large letters.  Unfortunately, the router IP address,
login, passwords, MAC address and such are printed on the modem in
dull gray on a black background the smallest possible font.
Enter Comcast, who initially inscribed their login and password on a
bright yellow sticker attached to the sides of their gateway boxes.
This was convenient for both user and the hacker.  However, noticing
that AT&T was making their boxes more secure by hiding the label under
the box, Comcast followed suit.  Despite the larger Comcast gateway
boxes, Comcast used a tiny label with a very thin letters in a tiny
size font that required a magnifier to read.  This improvement
graduated to a complaint, so Comcast moved the label to the back of
the gateway, where it could be buried and hidden under the usual
clutter of wires and cables.  At one point, Comcast actually did it
right with the setup information on a big yellow label on the side,
and passwords on a much smaller label on the bottom.  However, that
didn't last.  I'm not sure of the current location and visibility of
the Comcast gateway logins and passwords.
Jeff Liebermann     jeffl@cruzio.com
150 Felker St #D    http://www.LearnByDestroying.com
Santa Cruz CA 95060 http://802.11junk.com
Skype: JeffLiebermann     AE6KS    831-336-2558
On 6/14/19 9:34 AM, Char Jackson wrote:
<snip>
Well, I suspect the worry isn't someone locally reading it. Assuming the
username/password are unique to the device, that's at least better than
hard-coding in a field that is non-unique and accessible to the internet.
Site Timeline
