I have an interesting problem
Threaded View
I have a Linksys BEFW11S4 Wireless-B router. When I installed it, I used
128-bit WEP compression on it and saved a passphrase.
My laptop's OS crashed a couple of weeks ago and I figured it was a good
time to upgrade to Windows XP.
I can see my router from the 'Available Wireless Networks' window. However,
(correctly) according to windows the router is WEP-encrypted. But for some
reason, when I enter my passphrase, I get a Windows message saying that it
has to be a 40-bit or 128-bit key and can only be a certain number of ascii
characters.
Any ideas?
Thanks in advance.
Schiz
Re: I have an interesting problem
First, if your router and access card support it, switch from WEP to WPA.
That should solve things and encryption will be much stronger.  On the other
hand, if you can't...
Unlike with WPA, there is no standard for generating a WEP key from a
passphrase.  Thus, you need to know the key your passphrase generates when
you enter it in the router (your router should display this).  This key then
needs to be entered in XP.  For whatever reason (and I do not know if this
has been fixed in SP2), you cannot copy and paste the key from a web page.
Apparently, XP's wireless config program cannot properly handle formatted
text.  What you can do is copy it from the router's config page (formatting
is present), paste it into Notepad (formatting is removed), copy it from
Notepad (no formatting is present) and now paste it into XP's wireless
config program.
-Yves
> However,
> ascii
> characters.
> Any ideas?
> Thanks in advance.
> Schiz
The problem is that I don't have access to the router, therefore I don't
have the key.
If I had access to the router, I would have simply deleted the WEP
encryption.
other
then
(formatting
> config program.
> -Yves
> > However,
some
it
> > ascii
> > characters.
> > Any ideas?
> > Thanks in advance.
> > Schiz
> have the key.
> encryption.
> other
> then
> (formatting
>>config program.
>>-Yves
>>>However,
> some
> it
>>>ascii
>>>characters.
>>>Any ideas?
>>>Thanks in advance.
>>>Schiz
So, you are trying to steal service from somebody's router?  And we should
help you why?
OK, if you have permission to use the WAP but don't personally have physical
access, then ask a person who does have access to log into the router's
WEPkey setting page and copy down the passkey.  You can then type this into
your WirelessWidget's configuration page.
Cheers, Bob
> help you why?
Bob, please read my original post. I wiped my hard drive and upgraded the OS
after I encrypted the router. I remember the passphrase, but unfortunately
Windows XP does not accept passphrases, it only accepts encryption keys.
So no, I am not trying to steal service from anyone else's router.
physical
into
I have physical access to the router, but how do I enter the passphrase when
Windows only accepts a key?
>>help you why?
> physical
> into
Use a PC which has a wired connection to the router to log into the router
and capture its passkey.  That is one of the reasons why it is a good idea
to have at least one PC wired to a router for a network subnet which is,
basically, wireless.
If you do not have and cannot borrow a wired PC, then you can try giving
the router a hard reset:  turn off its power and leave it off for a minute
or so.  Some routers will forget all stored params, including the pass stuff.
It may help if you hold down the reset button while powering it back up,
and you may want to try resets, both soft and hard, a couple of times
because some routers are a bit flaky.
Cheers, Bob
stuff.
I followed some other advice on this forum and I reset the router. It no
longer has a passphrase stored or any WEP encryption and it is using it's
default SSID (linksys).
I can now see the router and log into it (by typing 192.168.1.1 in the
address bar of the browser), but I cannot still access the internet for some
reason.
My router is a Linksys BEFW11S4 and Wi-fi NIC is a Linksys WPC11. My OS is
Windows XP Professional.
As for accessing the internet, did you reboot your cable model after
connecting the router?  Most cable modems are configured to only assign a
single IP address (this may be visible if you connect to your cable modem;
many are found at 192.168.100.1; in general, you can only see diagnostic
info and cannot make any changes to the configuration).  If you were
connected by USB and then connected the router by ethernet, the cable modem
would have been unlikely to assign the router an IP address.
If you type "ipconfig /all" from a command prompt, do you get your ISP's DNS
servers?  The gateway should display as your router's IP address of
192.168.1.1 and your IP address should be 192.168.1.something.  Also, your
router should have a configuration screen showing its cable modem-assigned
IP address, DNS servers, etc.  Some of those entries should match what you
see under ipconfig.
-Yves
>> router
>> idea
>> minute
> stuff.
> some
> reason.
Sorry for top posting.
So does that mean that I need to physically enter the DNS server addresses
of my ISP? I don't think I had to do that with Roadrunner.
Yes, I had my laptop connected by USB to the cable modem, and the cable
modem connected by ethernet to the router.
I have no problem logging into the router when I disconnect the USB.
However, I cannot get onto any Internet site. I've read conflicting
information on whether I need to specify MAC addresses.
When I do an ipconfig when connected to the router (with USB disconnected),
I see my laptop's IP address (192.168.1.100) but no IP address information
in the router's configuration menu. I simply have get the 'Obtain IP Address
Automatically' option.
I never had this problem when I installed it the first time.
modem
DNS
> see under ipconfig.
> -Yves
> >> router
> >> idea
is,
giving
> >> minute
> > stuff.
up,
it's
> > some
> > reason.
is
Disconnect the router from the cable modem and turn it off.  Turn the cable
modem off and then on (most do not have a power button so you may have to
temporarily unplug it from its power supply).  Then, connect the router and
turn it on.  Connect your computer to the router and look at the
configuration screens of the router.  Your router should be assigned an IP
address (and Gateway and DNS addresses) by the cable modem.  Also, your
router should be set to obtain an IP address through DHCP.  Did you ever
have to clone your computer's ethernet hardware address into the cable
modem?
-Yves
> disconnected),
> Address
>> modem;
> modem
> DNS
>> your
>> modem-assigned
>> you
>> see under ipconfig.
>> -Yves
>> >> router
>> >> idea
> is,
> giving
>> >> minute
>> > stuff.
> up,
>> > no
> it's
>> > some
>> > reason.
> is
No, I never had to clone the address.
cable
and
> modem?
> -Yves
addresses
> > disconnected),
information
> > Address
a
> >> modem;
diagnostic
> > modem
ISP's
> > DNS
> >> your
> >> modem-assigned
> >> you
> >> see under ipconfig.
> >> -Yves
> >> >> router
good
> >> >> idea
> > is,
> > giving
> >> >> minute
pass
> >> > stuff.
> > up,
times
> >> > no
> > it's
the
for
> >> > some
> >> > reason.
OS
> > is
No, that's just an indicator.  Some routers provide themselves as the DNS
server, some provide the IP address fed to them by the ISP.  If you have
the ISP's addresses there, you are definitely connected.  If you have your
router's address, it might be a bad thing, but maybe not.
Some cable companies will "register" any MAC address.  Others only accept
one.  If you plug some other PC into the cable modem and try to open a web
page, it takes you directly to a MAC registration page.  If you plug in a
router, it won't let you connect to any page on the internet, although you
might be able to get to the registration page if you put in the address
directly.
> disconnected), I see my laptop's IP address (192.168.1.100) but no IP
> address information in the router's configuration menu. I simply have get
> the 'Obtain IP Address Automatically' option.
ipconfig /all returns more information, but I don't think we care.
Did you install it, or did the cable guy do it?  Maybe you did a "clone
MAC" the first time, and just forgot about it.  The clone Mac would go away
with a hard reset of the router.
Do an ipconfig /all and note your "Physical Address".
Put that value into the "advanced"-"clone mac addr" page of the Linksys.
Uhoh.  I just reread what you said.  You connected your PC via USB to the
cable modem.  That is a different setup than plugging in via ethernet, and
I don't know what the equivalent MAC address would be to put in as the
clone.
Perhaps you can see it in the cable modem configuration page, which should
be visible at http://192.168.100.1 Look for "known addresses".
Maybe you should just call your friendly cable modem ISP support desk.
When I told them that I was going to add a router, they offered to do the
authorization of the new MAC for me.  I chose the "clone" process instead.
Clarence A Dold - Hidden Valley (Lake County) CA USA  38.8-122.5
addresses
I solved the problem by hard connecting another laptop into the router and
using Linksys's own configuration utility.
With 64-bit WEP enabled, I clocked just north of 3000 kbps on the CNet
Bandwidth Meter. I wonder whether it will  be much faster with WPA
compression instead.
>have the key.
I'll assume that it's your router.  Just reset the router to defaults
and start over.  Then use either a 5 character (40bit) or 13 character
(128bit) WEP key.  What's happening is that when you enter the WEP key
in ASCII text, the firmware converts your text into hexadecimal
gibberish to use as a key.  That key has to be the exact correct
length (10 or 26 hex chars).  To make it easier to invent a suitable
WEP key, some vendors allow longer keys, and just use the first 10/16
hex chars.  That works fine until you run into a vendor that doesn't
believe in truncation and demands that you use the correct length key.
It's really ugly in a mixed environment.  If that seems to be the
problem, try using on the first 5 or 13 ASCII characters of the known
WEP key, or just use a hex WEP key with is always the correct 10 or 26
hex chars in length.
>encryption.
On the other hand, if it's NOT your router, methinks you should make
your peace with the owner or cease trying to abuse his wireless
system.
Jeff Liebermann    jeffl@comix.santa-cruz.ca.us
150 Felker St #D   http://www.LearnByDestroying.com
Santa Cruz CA 95060    AE6KS  831-336-2558
> system.
Please read my response to Bob regarding router ownership.
40 bit ascii can be a word like apple
128 (actually 104) can be a word like appleandpeach
You are probably trying to input the key in hex. You might search for a hex
to ascii conversion table and see if you can transate the hex back to ascii.
apple in this case is hex 61 70 70 6C 65
However,
ascii
> characters.
> Any ideas?
> Thanks in advance.
> Schiz
> used 128-bit WEP compression on it and saved a passphrase.
> good time to upgrade to Windows XP.
> However, (correctly) according to windows the router is
> WEP-encrypted. But for some reason, when I enter my passphrase, I get
> a Windows message saying that it has to be a 40-bit or 128-bit key
> and can only be a certain number of ascii characters.
> Any ideas?
> Thanks in advance.
> Schiz
Reset the router to factory: hold in the reset button for a minute.
Connect to the router wirelessly without security, enter the WEP
passphrase, and *copy the first generated key* to use on the computer.
Alternatively, connect to the router by ethernet and copy the key.
Q
> > Any ideas?
> > Thanks in advance.
> > Schiz
> Q
The laptop I use at home is an old, clunky Dell machine that does not have a
ethernet card, so I couldn't directly plug it into one of the ethernet port
on the wireless router. I have temporarily circumvented the problem by
connecting a USB directly from the cable modem to the laptop.
I remember the password of the router and was trying to connect to the
192.168.1.1 address wirelessly but I couldn't.
So I am thinking of taking my office laptop home today and connecting to the
router by ethernet. If I am directly plugged into the router, will I be able
to access it?
Also, I thought the WEP encryption would prevent me from going online, but
will let me access the router. It does not let me do even that.
On another note, does WEP degrade performance? Are there any alternatives
anyone can recommend?
Thanks in advance.
WEP will encrypt everything between your computer and the router.  Thus, if
you do not have the correct key, you cannot connect to the router
wirelessly.
As has been mentioned by others, the easiest solution is to just reset the
router.  There should be a button somewhere on the router that you would
need to press for a few seconds (perhaps while turning on the router).  That
will restore the router to its factory defaults and will turn off WEP
encryption.  You router will also assume the name Linksys (or something like
that) and, until encryption is turned on again, anyone in the area with a
wireless card will be able to connect to it.
-Yves
>> > Any ideas?
>> > Thanks in advance.
>> > Schiz
>> Q
> a
> port
> the
> able
> to access it?
> Thanks in advance.
if
> wirelessly.
That
like
> -Yves
Thank, Yves. That seems to be the simplest solution. You had mentioned
something about WPA encryption. Is it more efficient that WEP? How do I know
if my router/wireless card is capable of handling this type of encryption?
Thanks,
Schiz
Site Timeline
