Anyone try the Hawking Range Extender hooked to a Linksys SpeedBooster Router WRT54GS to boost a signal?
I never tried this but have tried a Linksys Router with SB WRE54GS and then the untethered Linksys Range Extender WRE54G (which operates as a repeater/booster with no connection) with success.
They say the Hawking can be configured with different power levels and such.
I guess I am just seeing if they both are equal or there is the downside that:
- Mixing and matching products may not work (Hawking said it should be fine).
- That in perhaps a large house (grandparents) that the Hawking would not cover it and I would need the wireless Linksys version that I could place ANYWHERE I want (with perhaps a different SSID as well).
Thanks Patty
