I have had for years a 4 PC HPNA network using both Netgear and Linksys cards. This always worked very well for me until I removed them to try some other types of networks.
In trying to return to HPNA, I remember that one pc must remain on with as the gateway along with ICS.
I remember that the setup automatically set up the IP and such for the gateway and the remotes all connected automatically. Does anyone remember the setup?
As an alternative, if I obtained the USB type of HPNA adapters, would I then need an additional phoneline network adapter or would they install as the PCI type does?
