I'm looking for help with a wireless issue on my new laptop. I just purchased an HP zd7160 with a Broadcom 54G MaxPerformance built in wireless LAN adapter.
This connects fine (and stays connected) to my 2wire 1000sw dsl wireless router - but when I move to where my D-Link 800AP+ repeater kicks in, my laptop loses the connection. It actually shows that it has a very good wireless connection to the D-Link, but I cannot access my network.
It is almost like it is connected but thinks the D-Link is a separate network and/or is not authenticating with it.
I use 64 bit WEP security and have set everything with the appropriate
10 digit security code.I have an IBM thinkpad which does fine when moving between the 2wire and the D-Link.
I've spent hours and hours on line with HP tech support, and have downloaded a multitude of softpaqs and driver updates, but nothing has helped. As soon as I go to where the laptop switches to the D-Link I lose connectivity.
I also installed a D-Link DWL-122 USB wireless to this laptop and it has the same problem, so it does not appear to be the broadcom adapter itself...
Any ideas/suggestions would be greatly appreciated.
Thanks,
Matt
