So when I woke up this morning, my HP zd8230us no longer sees any wireless networks. I've been rummaging around through this forum and found this info...
The possibilities (in order of most likely):
- There is a wireless button or on off switch somewhere on your laptop. For HP, it's usually a button dead center above the keyboard area, with a bright blue LED that's lit when the wireless is enabled. Sometimes, it's a slide switch on the front left of the laptop. It's there, somewhere.
- Windoze will allow you to enable or disable the wireless device. Go unto: Control Panel -> Network Find the wireless device. *RIGHT* click and see if it says "enable" or "disable" at the top of the list.
- The BIOS sometimes has a wireless enable or disable setting.
...which I've already gone through. BIOS is enabled, Network through the control panel is enabled, WZD (I think thats what the initials were) is started and automatic...
..But my little antenna button on the top of my notebook isn't turning on. When I press it, nothing happens. When I rt-click on the antenna in the taskbar and click turn on all devices, a balloon pops up and says everything is DISABLED. :huh: An uninstall and reinstall of the HP wireless assistant has not fixed the issue. Oh, and the router is working perfectly fine (my XBOX still works wirelessly).
So I'm baffled. Sorry for the wall of text, but any help would be greatly appreciated!!!
