I just installed a wireless adapter in a desktop pc to connect a HP pavilion notebook.
I shared the Internet connection on the desktop and the HP can surft without probleem. Also one PC can ping to the other, but there seems to be a trouble to connect the Windows networks (both with XPhome) Each PC see only itself.
For that reason I want to trying changing the channel. On the desktop it is easy 'cause the NIC came with setup soft but I just can't find out how to do this on the HP notebook ...
Is there a good utility (running under XP) to see which channel is in use and eventualy change it ?
Regards, Georges
