If email is enabled and properly configured, the RAZR V3xx can be used to wirelessly email digital photos from regular digital cameras that use removable memory cards compatible with microSD used in the RAZR V3xx. For example, a regular digital camera that uses SD cards can store digital photos on microSD cards by means of inexpensive microSD to SD adapter.
microSD adapters are available for SD, miniSD, and MemoryStick Duo, as well as Compact Flash by means of microSD to SD adapter inside SD to Compact Flash adapter.
The reason this works is that digital cameras store photos in a \\DCIM directory, and while the RAZR V3xx normally stores files in the \\mobile directory, it can also access multimedia files stored in the \\DCIM directory. Since the RAZR V3xx doesn't support large high-resolution photos, it displays a red X instead of a preview image.
The sending method is to create an email message, and attach digital photo(s) to the message.
Some online digital photo sharing services are able to automatically receive, store, and display digital photos sent by email (e.g., MyPhotoAlbum.com).
