Howto connect a nokia 3660 cell phone to the internet
Someone will, i'm sure offer more info, but to start, its much like adding another modem, you need to add the cell phone to your list of dial up connection devices. Depending on your o/s, find where your "Dial Up Networking" is then the "add a new connection" and with your cell phone attached, add it to the list of devices, your o/s should have it on the list. Then just enter the dial up info and you should be able to connect fine. Hope this helps... Any probs, let me know your o/s (operating system) is and i'll try to help more...
Roland
Who's your (cell service) provider? Some do data, and some don't.
Peter Pan
Update.. The phone on phonescoop shows as a GSM phone
Again, it depends on your provider, but you may want to try the Newsgroups specific for that provider (like alt.cellular.(provider) )
Peter Pan
Hello, Need some help on how to connect my cell phone to the internet using my isp provider. The manual that came with it is not very clear. I currently have a dial-up and after asking my isp they are useless. The phone as a built in modem so it should work. thanks for your help
mike
