How to use WRT54G for Wardriving?
I have a WRT54G which I use as a Router to the Internet.
Is there a way I can use my WRT54G to scan for close by WiFi Access points? I know software like NetStumbler can only be used with a WiFi Card.
Any ideas?
Thanks, Derek
JulyDerek
Go and read the forums on
and search for those posts regarding running the kismet drone on the WRT54G
David Taylor
Thanks guys!
But the process seems too difficult for a new Wifi enthusiast..... :-)
burzinb
Den Tue, 18 Oct 2005 17:50:19 +0000. skrev David Taylor:
Or better yet, go visit the Church Of WiFi, where there are how-to's posted on setting up the Kismet_drone on a WRT54G, as well as running Kismet_server under Cygwin on a Windows box.
and check out the Projects section.
e-teori
e-teori
