've got an Asus netbook something or another running the most recent update to XP.
We've got a (T-Mobile branded) Linksys here for use as an access point. The netbook does fine when it hooks to it.
But... every so often the netbook seeks and finds the neighbor's Linksys first. Which works ok, but isn't very neighborly of me.
Oh, and their signal is "marginal" whereas ours is "good".
I can manually reset it, but I'd rather have the netbook choose ours.
(the SSIDs are different, as are the channels).
There's probably a simple setting that I'm overlooking.
Suggestions?
Thanks.
