I'm setting up a Ubiquiti Nanobeam M2 400 as an access point, wired to a router which itself is wired to the main router, which itself is connected to a WISP antenna on the roof.
Here's where I'm stuck. Anyone know the next step?
First, I reset the Nanobeam to factory defaults.
- I connected the Nanobeam to a 12-to-24VDC 500ma-to-1A POE port RJ45.
- I ensured the Nanobeam first of six LEDs is lit green (power LED).
- I held the reset button in for about a dozen seconds (all lights flash). NOTE: There is no need to cycle the power; it can stay on all this time.
Then I connected to the Nanobeam from a Windows XP computer:
- Connect the POE LAN port to the WinXP computer RJ45.
- Start > Settings > Control Panel > Network and Internet Connections > Network Connections
- Check that the wireless Network Connection is disabled (it's too confusing).
- Right click on the "Local Area Connection" & select "Properties".
- Doubleclick on "Internet Protocol (TCP/IP)"
- Write down the settings (because you need to reset them when you're done).
- Doubleclick on "Internet Protocol (TCP/IP)" & set is as follows: (o) Use the following IP address IP address 192.168.1.199 Run > cmd C:> ipconfig Ethernet adapter Local Area Connection: Connection-specific DNS Suffix . : IP Address. . . . . . . . . . . . : 192.168.1.199 Subnet Mask . . . . . . . . . . . : 255.255.255.0 Default Gateway . . . . . . . . . : 192.168.1.20
- On WinXP, bring up a browser and log into http://192.168.1.20 Username = ubnt Password = ubn
Now what?
