how do i do this so if a person passing cannot use my connection for the outside
--------------= Posted using GrabIt =----------------
------= Binary Usenet downloading made easy =---------
-= Get GrabIt for free from
Enable encryption with a long nonsense passphrase. WPA is preferred, but
WEP will suffice as long as you change the encryption keys / passphrase
about once a week. Also password protect your wireless router's /AP's
menu configuration so that no one can make changes to your settings.
Change the default SSID and enable MAC address filtering. Example of a
long nonsense passphrase is:
7C&0(SXh)hI;u--5YDDgr*jrB^sr9($ZW0)B56p4NZB:P3;2__hyt#IZs^ Vw3gCabling-Design.com Forums website is not affiliated with any of the manufacturers or service providers discussed here. All logos and trade names are the property of their respective owners.
