Hi:
I am running Windows XP SP1. I installed Belkin Wireless Desktop PCI Adapter. The problem is that, everytime I login to Windows XP, my computer connects to wireless network. But, I would like to manually turn on the wireless connection after I login, since sometimes I do not need to connect to internet. I called the Belkin customer support, but he told me it is not possible. I have difficuilty believing that. I turned on the Wireless Zero Configuration service on and off, but it did not help. Belkin utility has a radio option that I can disable but then I need to do this everytime before I shutdown the PC. I will really appreciate any pointers.
Thanks.
