I have a workshop that is 300 feet from my house.. I want to set up a computer in it and access the same wireless signal that is currently in my house.. Currently I have a wireless G router and I am wondering whether I should switch to the newer wireless N system or whether I should stick with wireless G and try to make directional antennas out of cans (as described on the internet).. (I haven't read about anybody making "homemade" directional antennas that work with the Wireless N system so I assume that the complexity (of 3 antennas) involved is too great).. My question is whether the wireless N signal can extend to 300 feet.. there is a clear "line of sight" between the two buildings ... My other question is whether I might be better off trying to run a cable between the two buildings.. I have plenty of two wire electrical cable (which I presume is not the right stuff) and also have 6 wire telephone cable. (I don't like the thought of leaving it lying on the ground so might want to bury it 6" or so).. Does anyone have any thoughts as to how I can best approach this situation..
- posted
15 years ago
