How to find out ip address of ap
I think that 0.1 instead of 1.1 only works on dlink waps.. By the model # wap54g he gave, it's probably a linksys.
Just out of curiosity, do you have a wired or wireless connection? Some ap's (the wap54g and wrt54g specifically), have an option to set administrative changes are allowed from wireless (yes/no).
Peter Pan
On Thu, 20 Jan 2005 09:49:25 GMT, joecov spoketh
The default IP address of the WAP54 is 192.168.1.245.
Lars M. Hansen
'badnews' with 'news' in e-mail address)
Lars M. Hansen
Whats the easiest way to find out what the ip address of an access point
is? I have a wap54g at my workplace but cant find the install cd, also
192.168.1.1 does not appear to be working, or is there not a web based
utility for ap's? only for routers? Any help would be great thanks
joecov
Try 192.168.0.1?
Marcus
Marcus Fox
On my router, I can set 192.168.[0-255].1. The other numbers can be changed as well. You may also have a 10.0.0.1 network or whatever. Go to Start > Run and type "cmd". Then type "ipconfig /all" (without quotes, and there is a space beween ...fig and /all). The number it gives under Default Gateway is the address of your wotsit.
Marcus
Marcus Fox
Did you reset the WAP54G back to its factory defaults?
Neill Massello
------------------------------------- Hai you can try the following steps to find your ip address
Goto RUN Type cmd dos command opened now, here type ipconfig/all Now your internal ip address shown..
If you want to find your external ip address just visit
kalavani
