snipped-for-privacy@hotmail.com (Axel Hammerschmidt) hath wroth:
True. The Wiki/FAQ is built on user contributions. Contributions and corrections are always welcome. There are plenty of topics that have not been mentioned or are incomplete.
The issue I raised is about the characteristics of different types of interference that could possibly cause the OP's "dead spot" or "spotty reception". I suggested that this would imply continuous interference. Since interference is *YOUR* theory, and allegedly responsible for possibly causing the OP's problems, could I trouble you to suggest what manner of device could possibly cause continuous interference? Also, some remedial measures as I find it odd that you would suggest tweaking timing parameters rather than identifying the cause and either eliminating or avoiding it.
Correct. "spotty reception" implies that there is some reception in the bedroom. An increase in signal strength should improve the situation. If the house is long and narrow, redirecting some of the RF in the direction of the bedroom will be a big help. If the wireless router is at one end of the house, and the bedroom at the other, this would be ideal for an antenna reflector arrangement.
Sorry. I wasn't specific enough for you. I'm suggesting that the OP move the wireless device (laptop or desktop) to various locations in the bedroom to avoid any possible null and reflection problems. I don't think that moving walls will be cost effective.
True. But it's so much fun to speculate or guess(tm).
Usually, the OP supplies additional detail at this point, but he's apparently given up and considering power line networking. That will work and is easier if he can find a common power line segment.
So, what does one do for dead spots? In order starting with my favorite: 1. Bigger or better antennas. 2. Additional access point with CAT5 wire backhaul to main router. 3. Better technology (MIMO). 4. Powerline, phone line, or CATV bridging. 5. WDS bridge. 6. Repeater. 7. Bi-directional amplifier. 8. Dead Spot Remover:
As I previously mentioned... I advocate playing with every single last lousy setting in the router just to see what happens. Who knows, one might find something interesting, useful, or entertaining. One might also learn something. In every router that I have owned, I make it a point of understanding and testing all the settings. No big deal on a commodity router, but a major challenge with a WRT54G and DD-WRT firmware. It's all part of Learn By Destroying(tm). In the case of the current "dead spot" problem, I predict that adding flow control will not do anything useful.
Use a shofar. ...and the walls came tumbling down.
I don't see where you get that implication, but I can guess(tm). Usually, interference reduction is measured using the signal to noise ratio. That was fairly straight forward with analog receivers. The signal strength versus the remaining noise level between packets. However, with the introduction of all digital receivers, there was a change to measuring the SNR using the error rate. 100% reception success, with no corrupted or trashed packets, was deemed perfect SNR. If corrupted packets were decoded, the SNR value was reduced. The correlation is marginal with the previous analog methods but good enough for site surveys and antenna aiming.
In this SNR case, you are correct. Increasing the probability of a packet arriving without corruption, by reducing its size (i.e. fragmentation), or preventing transmission when the channel is "noisy" (RTS/CTS flow), would improve the SNR. The only problem is that both will slow down the thruput considerably.
Incidentally, CTS/RTS is the common term for modem flow control. RTS/CTS is the common term for wireless. I guess I'll have to change over to using RTS/CTS. Sigh.
