Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by catalyst on April 14, 2008, 10:07 pm
Please log in for more thread options with lmr cabel. I have some difficulties, i would need this aP to work in client mode so i could put it on my house-roof. Is there a way to flash this ap, i tried to find some utilities.... | |||||||||||||||||||
Posted by DTC on April 15, 2008, 2:11 am
Please log in for more thread options That doesn't appear to be a mainstream device. Bite the bullet an buy a $70 or so Linksys WAP54G Access Point and select client mode operation. | |||||||||||||||||||
Posted by seaweedsl on April 15, 2008, 11:47 am
Please log in for more thread options > hi! I bought myself a benq Awl 500 AP
The Benq does not appear to have a client mode, nor, it seems, does it do WPA security. Though it does support Radius... If you can return it, do so. There are others that do more and are cheap enough. The ASUS routers have USB ports and support DD-WRT firmware which adds many many functions, including AP, Client Bridge, Bridge Repeater,WDS etc. Also Tomato firmware works on it and is said to be very simple and reliable as a router, client or AP. http://www.newegg.com/Product/Product.aspx?Item=N82E16833320023 Return the Benq or keep it as an AP someplace that doesn't need effective security. Steve | |||||||||||||||||||
Posted by catalyst on April 15, 2008, 8:53 pm
Please log in for more thread options Wow, thank you guyz!
http://www.netstumbler.org/avatars/mikep928-405.gif?dateline=1162187676 Salute! >> hi! I bought myself a benq Awl 500 AP
> The Benq does not appear to have a client mode, nor, it seems, does it > do WPA security. Though it does support Radius... If you can return > it, do so. There are others that do more and are cheap enough. > > The ASUS routers have USB ports and support DD-WRT firmware which > adds many many functions, including AP, Client Bridge, Bridge > Repeater,WDS etc. Also Tomato firmware works on it and is said to be > very simple and reliable as a router, client or AP. > > http://www.newegg.com/Product/Product.aspx?Item=N82E16833320023 > > Return the Benq or keep it as an AP someplace that doesn't need > effective security. > > Steve | |||||||||||||||||||
how to do a wireless ?
Yahoo!
Windows Live
del.icio.us
digg
Netscape
