,and install it. You can know more about it by referring here. [image:
the DVD you'd like to convert to your computer's DVD drive. [image:
Click 'File' menu and 'Open DVD', or directly hit 'Open DVD' button to load the DVD. Set the profile to be iPhone 480*320 mpeg-4 video which is the default DVD video quality.
- Click around in the DVD's menu to set up DVD playback as you like, select the subtitle and audio sound tracks etc, then begin to play the movie through the software by click the play button.
- The following window will pop up. Here, you can rename 'Title Name', set 'Save Path' and output quality, then click 'Yes' button to start ripping DVD to iPhone MP4 or iPhone H264 video from the point that the movie starts. That is all. Just so easy! [image: formatting linkyou'd like to record from certain time point, or want to change some parameters like 'output format', 'video bitrates', 'frame rate', 'audio bitrates', please click 'No' button to close the window.
- Select subtitles and languages Click 'Subtitle' or 'Audio Track' in the 'Setting' menu, choose the related value you like.
- Set output formats Choose the target file format from 'Profile'. The software supports converting DVD to iPhone 480*320 MP4 video,iPod MP4 video, iPod h264 video, MP3 audio. [image: formatting link
